Hey everybody,
I would like to upgrade my graphics card and power supply, but I do not have much knowledge on computers. However, from the research I have done, I understand that upgrading to a better graphics card is not as simple as just buying one. It has to match the motherboard, and you have to have the correct power supply right?
I bought a prebuilt PC from Best Buy a few years ago and it is a HPE-210y and I found the specs from another forum and it was the exact model and product number that I have.
My current power supply is only 300W from the stock power that came with the computer and my graphics card is ATI Radeon HD 5450 with dedicated graphics memory of 512MB. I currently play Guild Wars 2, and I have to play it at the lowest settings and it is absolutely a shame to the game!
My questions are: What graphics cards can I buy that match my motherboard and is there an easy way for me to know this? My price range would be about $400 or so, but could be as low as $200, all depending on college fees, so if you have any suggestions I would appreciate it. Also, what power supply should I buy to be able to handle the graphics card around the $100-$150 range? Are there any power supplies that do not fit into the prebuilt case that came with my computer?
I feel like besides the graphics card and the power supply, my computer has a lot of other solid components for now, correct?
I appreciate all the help I can get!
System
Manufacturer HP-Pavilion
Model BK170AA-ABA HPE-210y
Total amount of system memory 8.00 GB RAM
System type 64-bit operating system
Number of processor cores 4
Storage
Total size of hard disk(s) 931 GB
Disk partition (C
(920 GB Total)
Disk partition (D
(12 GB Total)
Media drive (E
CD/DVD
Graphics
Display adapter type ATI Radeon HD 5450
Total available graphics memory 3571 MB
Dedicated graphics memory 512 MB
Dedicated system memory 0 MB
Shared system memory 3059 MB
Display adapter driver version 8.773.0.0
Primary monitor resolution 1920x1080
DirectX version DirectX 10
Processor
Model: AMD Phenom II X4 945 (HDX945FBGIBOX)
Speed: 3.0 GHZ
Socket: AM3/AM2+
Bus speed: 3600 MHz HT3
Motherboard
H-RS880-uATX (Aloe)
Manufacturer: Foxconn
Form factor: uATX
Chipset: AMD 785G
Memory sockets: 4 x DDR3
Front side bus speeds: 5200 MT/s
Processor socket: AM3
Expansion Slots:
1 PCI x16 slot for graphics card
3 PCI x1 slots
1 PCI Express x1 minicard slot
Computer
HPE-210y
I copy and pasted this question from another person, but I figured, it has almost been a year, I could get a bigger and better graphics cards, as well as a power supply.
The old thread is here
http://www.tomshardware.com/forum/315218-28-help-buying...
But I'd like an updated answer.
Thank you very much for reading, and I do appreciate it.
