I knew this day would come. It is time to upgrade the computer and the new boards (I am considering) do not have PCI slots, so now I need to find a sound card with PCI-Express slot. I am looking for something that is comparable to the cards I have now (Auzentech Meridian 7.1 with upgraded opamps and Bluegears B-Enspirer). Both cards are connected to the original Klipsch Pro-media 5.1 speakers (it is important to note that this speakers have front, rear and sub stereo miniplug connectors). I avoid sound cards by Creative because their drivers/software causes me problems.
I am assuming that something comparable will be around $200. If there is something less expensive that meets my needs, great. If it costs a little more, I am OK with that to. I just want a similar or better experience.
I primarily listen to music (wide variety). I will occasionally watch movies/TV. I am not a gamer.
What do you recommend?
Links to current products for your convenience
http://www.bgears.com/b-enspirer.html
http://www.auzentech.com/site/products/x-meridian.php
http://www.klipsch.com/promedia-5-1-computer-speaker-system
Thank you!
J
Thank you!
J
