Hello,
I have a little bit of an issue, once when I was playing BF3 my PC suddenly shut down and would not turn back on, the fans were spinning and no boot, so I changed power supply and it did turn on and then after maybe 10 minutes of game play it did the same thing but now it would not power up whatsoever. I could smell the specific warm smell from the case and I thought the mobo went but I got a new one and still it does not power up. The power (standby) light on mobo is on but no power up.
My current hardware is:
AMD Bulldozer FX 8120 x8
Asus M5A97Pro (new mobo)
Corsair Vengeance 16GB 4x4
3 x 500GB Seagate HDDs
MSI/ATI RADEON 6970
EVO Labs 750W PSU
I have tried several things already:
1. using different cpu (Athlon II x2 )
2. unplugging all of the peripherals leaving just psu, cpu, mobo and one ram
3. same as point 2 but swapping the ram
4. taking mobo out of the case and repeating steps 2 and 3
5. using different GPU (HD6450)
What do you think about this problem? I am so confused now it is unbelievable...what else could I do in order to test components, I need to underline that I do not have another pc to test the components with :/ I am really dying to know because I spent so much money on this PC and it just does not work, any input is strongly appreciated.
Regards,
techspeque
MSI/ATI RADEON 6970
EVO Labs 750W PSU
Regards,
techspeque
