Power Supply Help
Last response: in Components
September 17, 2012 2:23:41 AM
Hi guys i'm wondering how much power do I need and I would prefer if it was not so expensive, preferably modular.
CPUIntel Core i5-3570K 3.4GHz Quad-Core Processor
CPU COOLERCooler Master Hyper 212 EVO CPU
MOTHERBOARDGigabyte GA-Z77-D3H
RAMCorsair Vengeance Low Profile 8 GB (2x4GB)
STORAGESeagate Barracuda 7200 1 TB
CASECooler Master HAF 912
OPTICAL DRIVEAsus 24xDVD-RW
VIDEO CARDMSI R7850 Twin Frozr OC AMD Radeon HD 7850 2GB
More about : power supply
a c 87 ) Power supply
September 17, 2012 2:45:43 PM
+1 to Obsidian.
m
l
a c 85 ) Power supply
September 17, 2012 2:58:29 PM
For the record I don't think that system will use more then 300W at full load. It might not even cross 250W. A 450W PSU will be more then enough. (not for CF of course so if you think you might want that in the future then get something like a 500 or 600W.)
m
l
September 17, 2012 9:29:36 PM
Z1NONLY said:
There are power supply calculators floating around the internet, but just looking at your system specs, a good 500w PSU should be plenty.
PC Power and Cooling Silencer MK III 500W Modular $60 after rebate.
I know about the calculators, but I didn't know if getting more than needed affected, and which to get. Thank You.
m
l
