First off this is the configuration:
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
CPU: AMD Phenom II X6 1055T
Cooler: Stock fan
RAM: 4GB G.Skill Ecogreen 1.35V (will replace with this: http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095 )
HD: Seagate Barracuda ST 320GB 7200RPM
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
So I'm running on what is essentially default settings. The hard drive has a full working copy of Windows 7 Pro installed on it. All of a sudden the CPU fan starts accelerating rapidly - to 6,100 RPM. My primary PC there's three fans and not a single one of them goes above 1,500RPM according to the BIOS. I go into the BIOS to try to fix the problem but it can't be done. So I load optimized default settings. Now I reset the machine and it gets to "LOAD OPERATING SYSTEM" and suddenly it says "BOOT MGR MISSING PRESS CTRL-ALT-DEL" despite the fact that I was in full Windows earlier.
Now the first question is what do I do about the CPU fan - do I contact AMD or Gigabyte first and attempt to RMA it? Second, what's going on with my hard drive - is it something that I can fix easily or will I need to try a different hard drive?
Cooler: Stock fan
