Greetings!
I have a Pegatron M2N68-LA Picture: http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01701274.jpg
and I want to upgrade my lousy 128MB integrated NVIDIA to this: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130752
My questions are as follows:
1. Case notwithstanding, will the card fit in the MOBO? I'm not the most visual-spatially inclined, but it looks rather tight.
2. Based on the photos, the card only appears to require a single PCI-E x16 slot. I find this kind of hard to believe. Would you mind confirming?
One side comment:
It seems that the mobo is PCI-E x 16 1.0, which means some of the oomph of the card will be wasted. I've conducted a CBA and determined that buying the card and necessary PSU is justified over replacing the entire PC right now. That said, I'm hardly an expert in graphics cards, and am quite open to suggestions aside from "get a real MOBO with an AGP." Believe me, if it was at all practical, I would.
Thanks immensely for any feedback. After lurking TH for 3-4 years, it's nice that I finally had a question necessitating registration.
Cheers,
EJ
One side comment:
Cheers,
EJ
