G
Guest
Guest
Approximate Purchase Date: 1-2 Months
Budget Range: 1000-1200$ Before rebate
System Usage from Most to Least Important: Gaming, Sony Vegas - Would like something that can run most games (bf3, minecraft, cod, wow) on high settings or better
Parts Not Required: Keyboard, Mouse, Screen
Preferred Website(s) for Parts: Newegg.com
Country: USA
Parts Preferences: Intel Build
Overclocking: No
SLI or Crossfire: No
Additional Comments: Quiet PC, Include OS in price (windows 7 home premium 64 bit)
________________________________________________________________________________________________________________________________
Parts i picked out not sure if they are all compatible this is going to be my first build
http://www.newegg.com/Product/Product.aspx?Item=N82E16827140042
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148725
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103089
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128544
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116506
total - 1,150$
If you can give me something better and cheaper please do
Country: USA
Overclocking: No
total - 1,150$
