For people having problems editing post...
Last response: in Forum Feedback
Quote:
Its customary to add a note as to why you edited your post
edit- fixed typos
Customary yes, but I find myself editing my posts more times than not recently, for typos and added info, that that would get a bit old after a while, lol.
If it was a REALLY important addition or a game-changing typo, I'll usually make a note of it though.
Related ressources
Need to be more comprehensive b4 sticky. Add things like tracking, show all thread, advance search, PM, PM black, reporting, change font colour, embed video, add book mark, edit new comment, etc...
Basically someone needs to write a manual for using the forum.
Also, this thread shouldn't be here yet.
This topic has been moved from the section CPU & Components to section Forum Feedback by Pyree
Draft here and if it is good enough, it will be sticky on other section.
jay_nar2012 said:
:hello:
I,ve finally figured out how to edit posts and this might help you aswell.
When you submit a reply, at the bottom of your reply you have 3 little symbols, you need to click the middle one, then you can edit your reply and then click submit your reply.
Hope this helped...
You can also use this thread to try it out.
:bounce:
Ask the community
