Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > HELP! WinXP Hanging at "Verifying DMI Pool Data"
Forum Windows XP : Windows XP General Discussion - HELP! WinXP Hanging at "Verifying DMI Pool Data"
I've really done it this time. :( I decided to merge two partitions on my mom's second hard drive using Partition Magic Pro 7, which is supposed to be Windows XP compatible. After booting to DOS, it hung and gave me an error message. Silly me, but I didn't write it down. I just shrugged and hit reset and now the computer hangs on "verifying DMI pool data." I can't boot into safe mode and I can't boot from the Win XP CD. I have the six boot disks and asked Windows to repair the installation, but it asks me for the Automated Recovery Disk, which I don't have.
1. How can I make a recovery disk?
2. Is there a way to access system restore given my limited options? (Can't even get into Windows)
Thanks For Any Input.
|_ /\ |) `/ |-| /\ \/\/ |<
Why is there braille on drive-through ATMs?
Sponsored Links
Goto the CMOS and select boot-up from CD-ROM. Then re-boot
and boot from XP installation CD-ROM. There is a recovery option in XP installation CD-ROM.
Goodluck!!
Reply to Caligula
Hi, I tried that already, but it fails to boot from the CD-ROM. (ATAPI boot failure...blah blah) After using the boot floppies, I can access the CD-ROM. I'm just not sure what to do with it. :) How do you access the recovery if you can't boot from the CD-ROM?
Reply to Anonymous
If I'm not mistaken, when you see the "Verifying DMI pool data" you are seeing an echo from the mobo that is detecting a change in the hardware. So your problem doesn't necessarily lie in WinXP, cuz (if I am correct) your system isn't even getting to the point of being able to load it. Try taking out (or just disconnect the ribbon and power to) the 2nd harddrive that you merged the partitions on (I'm assuming the 2 partitions were both on the 2nd drive?). If the DMI pool is what I am thinking it is, it should pass the verification and your XP should fire right up.. as for fixing the 2nd drive, I dunno... you may have just learned a lesson (and thanks for sharing it with yer friends!!)...
Ret
Reply to Retruglot
Thanks, dude. I'll give it a whirl. :)
Reply to Anonymous
I had that problem once and I tried everything, and nothing worked. At last I thought, the only thing I havn't tried is flashing the BIOS, maybe it is corrupt somehow. Sure enough, flashed the BIOS and it worked perfectly.
Reply to Anonymous
I don't see how Partition Magic could have screwed with the BIOS, but I suppose anything is possible. Perhaps I'll try clearing CMOS as a less aggressive step. I don't want to kill the thing any deader than it already is. :)
Disconnecting the second HD had no effect, BTW, but oddly, the primary master wouldn't be recognized unless the second drive was also hooked up. I tried all different positions on the IDE cables, just for kicks, but it was being very naughty...which makes you wonder about the BIOS...
Reply to Anonymous
Did you change the jumper setting on the primary drive to "Stand Alone" or "single drive" (if that is an option)? If not, then it wouldn't work without the 2nd drive becuz it would keep looking for that drive due to the primary drive expecting it to be there.
I'm not sure clearing the CMOS will make a difference, but let me know if it does... stranger things have happened..
Ret
Reply to Retruglot
There are 1086 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
  • 01:00 batuchka won the Uniformed badge
  • 01:00 Nick_C won the Uniformed badge
