Solved
Will this case house this RAM/Cooler?
  • Power Supplies
  • Performance
  • Cases
  • Cooling
  • Components
Last response: in Components
September 17, 2012 8:23:04 PM
Case: Fractal Design Arc Midi Black High Performance PC Computer Case w/ USB 3.0 and 3 x Fractal High Performance 140mm fans
RAM: Corsair Vengeance 8g (2x4) DDR3-1600
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
(Rest of the rig: http://imageshack.us/a/img59/1747/compy3.png)
If not what is a good case with great cooling capabilities/capacity that can properly house this set-up?
More about : case house ram cooler
Best solution
a b ) Power supply
September 17, 2012 8:44:46 PM
Use the corsair vengence low profile modules and you wont have a clearance issue between the ram & cooler..
Yes the cooler will fit your case.
September 18, 2012 12:20:56 PM
If I wanted to run both the listed CPU cooler and a high profile RAM, as these are all the best rated RAM - What would be a case analagous to the one I have that could fit them both efficiently?
m
l
September 28, 2012 2:27:12 PM
Best answer selected by awlips.
m
l
