Solved
$600 All-Around PC (No Graphics Card) Help?
Approximate Purchase Date: June 10 (In 2 weeks)
Budget Range:$600 After Rebates
System Usage from Most to Least Important: Gaming, Basic Video Editing/Rendering Videos, Movies
Parts Not Required: Speakers, Monitor, OS, Keyboard, Mouse, Graphics Card/GPU
Preferred Website(s) for Parts:Newegg, TigerDirect
Country: I don't care.
Parts Preferences:Ideally an i5 or better CPU. (Doesn't need to be IB though)
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution:1920x1080
Additional Comments:
I picked up a Sapphire Radeon HD 7850 already, so I would like to have the rest of the computer built to handle the card. I can stretch my budget to $650 if there is some kind of amazing deal on a motherboard or case, but I would definitely prefer not throwing in the extra.
Also, I live near a Micro Center, just to note.
This is my first build, and I'm not particularly tech-savvy, so any advice I can get on things that I can get on building the PC would be nice too.
Edit: This is what I am looking at atm
CPU:Intel Core i5 3570K 3.4GHz LGA 1155 Processor $189.99
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
$189.99
HDD: Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
$99.99
Case & PSU (Combo deal @ Newegg): CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply + Corsair Carbide Series 500R White Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.913272
$114.98 (After MIR)
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
$54.99
Motherboard: Z77 Extreme4 LGA 1155 Z77 ATX Intel Motherboard
http://www.microcenter.com/single_product_results.phtml?product_id=0387554
$89.99
Optical Drive: Sony Optiarc 24X DVD Burner, Bulk Package Black SATA Model AD-7280S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118067
$17.99
Mushkin Chronos 60 GB SATA 6.0 Gb-s 2.5-Inch Solid State Drive (MKNSSDCR60GB)
http://www.amazon.com/Mushkin-Chronos-2-5-Inch-Solid-MKNSSDCR60GB/dp/B005INAEJG?SubscriptionId=19BAZMZQFZJ6G2QYGCG2&tag=vglnk-c1001-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B005INAEJG
$67.99
Total Cost: $635.92
Good?
5 answers Last reply Best Answer
More about around graphics card help
  1. I would try to go for an Ivy Bridge i5 since you have a PCI-E 3.0 graphics card, Sandy Bridge only supports 2.0. It might not make a big difference but there's not much of a price difference either.
  2. Best answer
    Check out my $850 build here:
    http://www.squidoo.com/electronicandmore
    Since you live by Microcenter that's $60 off.
    Also since you've already got the 7850 that's $250 off.
    Total: $561
    Since you have extra left, use it on a quick little boot drive SSD.
    http://www.amazon.com/Mushkin-Chronos-2-5-Inch-Solid-MKNSSDCR60GB/dp/B005INAEJG%3FSubscriptionId%3D19BAZMZQFZJ6G2QYGCG2%26tag%3Dsquid1240995-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB005INAEJG
    Total: $561
    Actually, looking at the prices @ Micro Center, I can bundle the ASRock Extreme4: http://www.microcenter.com/single_product_results.phtml?product_id=0387554
    with the 3570k for $280. Do you think it's worth the upgrade?
  4. Yeah it's definitely going to be a nice bundle. Saves some money and the SSD can be even more affordable.
  5. Best answer selected by Merueth.
New Build Graphics Cards Systems Product
