I'm building a new system for my friend and I always like to double check the parts to make sure they will all fit together. So if you can tell me which ones may not work or if you recommend a different part. BTW it's staying AMD because hes on a budget.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103961
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817153106
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
DVD Burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Tower: Already have one its the NZXT Gaurdian
He already has a monitor, keyboard, mouse ect.
