Solved
Will this work well?
Just woundering...
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116397
MoBo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157315
Graphics - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
Will those all work fine together? What games could I run with good graphics settings with that setup?
2 answers Last reply Best Answer
More about will work well
  1. Best answer
    The Radeon 6850 is okay, I would personally go with a 7850 or 7870. The CPU and mobo are about as cheap as can be. It will play some games but none particularly well. I would recommend an i3 or an i5 if you're interested in gaming
  2. Best answer selected by Clp.
New Build Games CPUs Graphics Systems Product
