[New Build] HELP!!! $850 gaming PC Parts/Advice
Approximate Purchase Date: Between now and the end of June
Budget Range: No greater than $850, but the cheaper the better
System Usage from Most to Least Important: Gaming, Movies
Parts Not Required: ( keyboard, mouse, monitor, speakers, OS)
Preferred Website(s) for Parts: Newegg, Amazon, TigerDirect, ETC
Country: United States
Parts Preferences: Highest quality for cheapest price
Overclocking: Yes
SLI or Crossfire: Not likely
Monitor Resolution: 1920x1080
Additional Comments: I want a system that runs games smoothly and can utilize the best performance for the cheapest price. I play games such as Diablo III, League of Legends, Starcraft III, and WoW and look to have graphics that will handle future games. I already have purchased a cpu and Motherboard as seen below. I really need some sound advice on the correct ram and graphics card to choose for the money. I also want to know if i use a Rosewill Challenger will i be able to fit everything in the case? Thank you all so much for your help this is my first time building!
Include a list of any parts you have already selected with descriptively labeled links for parts.
PARTS I HAVE ALREADY PURCHASED
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504&Tpk=3570k
Motherboard- http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
I bought these for $300 on sale at Microcenter. I dropped by when i was passing through Ohio and received a good deal on the two. I will not be able to purchase any other goods at microcenter for this build
Parts I need to Purchase/ Ideas for purchasing
GPU- This is an area that is very important and i am very stuck on. I look at the GTX 560 TI for 210 right now and do not know if this is the best choice for my money. Please add suggestions for quality gpus that may be a better fit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
Ram- Hyperx, Vengeance, or other? I want the cheapest ram that can get the job done well.
Case/PSU- I found this combo at Newegg. Let me know what you think. Its a Rosewill Challenger with 750w PSU.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.915251
HDD- Unknown. Don't want an ssd just a quality harddrive 500gb+
Heatsink fan- http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Let me know what you guys think and if everything will be able to fit in that case or should i choose a different one. I really appreciate everyones feed back and hope that i can purchase this computer as soon as possible!
1 answer Last reply
More about build help gaming parts advice
  1. bump
New Build Systems Product
