Closed Solved
Triple-monitor stand (for eyefinity)
Hi folks, I'm looking for suggestions for a triple monitor stand.
I'm finally getting around to setting up a 3-monitor display, the monitors I ordered are 23" acers http://www.newegg.com/Product/Product.aspx?Item=N82E16824009266.
I'd like to have all 3 monitors mounted on a stand, so I have room underneath the 2 on the sides, not to mention it should look really cool. One I found that seems reasonably priced is http://www.amazon.com/Deluxe-Triple-Monitor-Standing-Supports/dp/B006JG9RQ2
but it has few reviews which makes me nervous.
Anyone have suggestions? I'm sure I can spend $250 for a great one but that seems ridiculously overpriced to me. Thanks for taking the time to read
-David
7 answers Last reply Best Answer
More about triple monitor stand eyefinity
  1. Ya I saw that one, doesn't seem to be much better than the one I linked and for quite a bit more $$
  2. Still looking, anyone have suggestions for a cheap but good triple monitor stand?
  3. Best answer
    Looked around a little bit and it seems like the one you have picked out is going to get the job done at the cheapest price. If it makes you feel any better, you can buy it from Ebay http://www.ebay.com/itm/Deluxe-Triple-Monitor-Stand-Free-Standing-up-to-28-/180840988000?pt=LH_DefaultDomain_0&hash=item2a1af67d60 and it comes with a 14 day refund policy.
    Good luck with your setup!
    Regards,
    Shinseina
    Regards,
    Shinseina
    Thanks, but it's cheaper at amazon, at least for now.
  5. Best answer selected by david42one.
  6. This topic has been closed by Mousemonkey
Graphics Cards Reviews Monitors Graphics Product Displays
