Solved
Pleaze !!!!! need help! are thes parts compatible
  • New Build
  • Systems
Last response: in Systems
May 27, 2012 6:55:17 AM
i dont know if these parts are compatible plz tell me and also if i would be able to play every game maxed out on 1920-1080.and how many gaming years will it last ? i wanna play games like bf3 mw3 batman arkham city
CAS:Azza Hurrican 2000 Full Tower Gaming Case with 4 Hot Swappable HDD Cage & (4) 230MM Fans
CASUPGRADE:None
CD:LG UH12LS28K 12X Blu-Ray Player & DVDRW Combo Drive (BLACK COLOR)
COOLANT:Standard Coolant
CPU:Intel® Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
CS_FAN:D efault case fans
FAN:Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
FLASHMEDIA:INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOr)
HDD:500GB SATA-III 3.0Gb/s 16MB Cache 7200RPM HDD (Single Drive)
IUSB:Built-in USB 2.0 Ports
KEYBOARD:Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard
MEMORY:8GB (2GBx4) DDR3/1600MHz Quad Channel Memory (Corsair or Major Brand)
MOTHERBOARD:( 3-way SLI Support) ASRock X79 Extreme 4 Intel X79 Chipset Quad Channel DDR3 ATX w/ UEFI bios, XFast LAN, Charger, & USB Technology, 7.1 HD Audio, GbLAN, USB3.0, SATA-III RAID, 3 Gen3 PCIe X16, 2 PCIe X1 & 2 PCI
MOUSE:XtremeGear Optical USB 3 Buttons Gaming Mouse
NETWORK:o nboard Gigabit LAN Network
OS:Microsoft® Windows 7 Home Premium (64-bit Edition)
POWERSUPPLY:800 Watts - Cooler Master Silent Pro Gold 80 Plus Power Supply (80+ Gold)
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO:NVIDIA GeForce GTX 670 2GB 16X PCIe 3.0 Video Card (EVGA Superclocked )
More about : pleaze thes parts compatible
May 27, 2012 6:59:52 AM
it will all work but the GTX 670 wont be maxing out games for long, its a solid card today though
m
l
May 27, 2012 7:20:01 AM
thanks for the reply.and can u tell me what card should i buy that could last for long atleast 4 to 5 years while i play games on max.i can spend 50-70 dollars more on a graphic card
m
l
May 27, 2012 7:20:07 AM
m
l
May 27, 2012 7:24:41 AM
This topic has been moved from the section CPU & Components to section Systems by Proximon
m
l
May 27, 2012 7:28:48 AM
The 670 will play all of those games maxed out.
m
l
May 27, 2012 7:41:41 AM
how much gaming years will my rig last for?
m
l
Best solution
May 27, 2012 6:25:52 PM
I would change the board to a z77 or z68 board and go with an i5-3570k or i5-2500k. This is because you are gaming, and no games use hyperthreading.
It should last for about 5-6 years, this is because you can keep adding graphics cards until you have four gtx 670's in quad sli.
June 6, 2012 12:27:37 PM
will my rig be great if i replaced gtx 670 with gtx 680 2gb
m
l
June 6, 2012 12:32:00 PM
Best answer selected by arslankhalid.
m
l
