Need help in choosing parts for new build
Hello,
This will be my first build, so please excuse any stupid moves on my part. I have a budget of around $1000. The parts I have chosen are here :
http://pcpartpicker.com/ca/p/8Xwy
CPU : Intel Core i5-3450 3.1GHz Quad-Core Processor
CPU Cooler : Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler
Motherboard : ASRock Z77 Extreme4 ATX LGA1155 Motherboard
Memory : Kingston 8GB (2 x 4GB) DDR3-1600 Memory
Hard Drive : Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive
Video Card : EVGA GeForce GTX 550 Ti 2GB Video Card
Case : NZXT Phantom 410 (Black) ATX Mid Tower Case
Power Supply : Corsair 750W ATX12V / EPS12V Power Supply
Optical Drive : LG GH24NS70 OEM DVD/CD Writer
Total Cost : $913.90
As I am very new to this, please feel free to recommend any replacements for cheaper/better products.
Thanks! :hello:
EDIT:
Approximate Purchase Date: End of June
Budget Range: $1000
System Usage from Most to Least Important: Gaming & Watching Movies to Light Browsing
Parts Not Required: Keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: newegg & canadacomputers
Country: Canada
Overclocking: No
8 answers Last reply
More about need choosing parts build
  1. http://pcpartpicker.com/ca/p/8XA5
    I'm at 1048, but it's a much better gaming build.
    ETA: get rid of the aftermarket cooler, you don't need it if you are not over clocking. That will get you right at $1000.
  2. You don't need an aftermarket cooler if your not overclocking, so save some money there.
    You don't need a 750w psu, a 500w psu would be more than enough.
    Use the saving to get a decent video card, at least a 560ti/HD6950/HD7850
  3. This is an updated version I created. Can somebody please verify that all parts are compatible and that the power supply will be enough?
    http://pcpartpicker.com/p/93x9
    As well, I am wondering is this a better buy for the memory:
    http://pcpartpicker.com/part/corsair-memory-cmz8gx3m2a1600c9b
    Thanks
    Thanks
    That Corsair Vengeance RAM is better. Everything else will work together. If you want to save a few more bucks, you can choose a cheaper case. Cooler Master Haf 912 is really popular. I have the Corsair 300R and I think it is a very good case (partly because I bought it on sale so I got it for the same price as the HAF 912). :p
    Thanks
    I'd recommend a 550w, a 500w will work but it'll be pushing it. I recommend something at least 80+ bronze rated. You missed all the memorial day deals.
    Could you please recommend a cheap one?
    On another note, will I need to purchase a sound card, or NIC or does this motherboard come with them? And it will come with a default heat sink right?
  7. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
    $50 after MIR
    The extreme4 has an ethernet port so no worries there.
    The CPU actually comes with a HS/Fan.
    ETA: Don't worry about a sound card unless you have some extreme surround sound system you are trying to run.
  8. Mobo has 8ch sound and nic.
    Unless your buying an oem cpu and I suggest you don't, it will come with a heatsink.
    I don't see any good psu deals at the moment, you missed the memorial day deals. Wait a day or two something will come up. Or Fathers Day.
New Build Systems Product
