Hello,
This is my first time on this forum and my first time building a PC on my own as well , I have already managed to find Pieces that will fit both my budget and my gaming requirments But i just wanted to know if everything would work together and also your opinion about the build. The build should be as following :
ATI 6850
AMD FX-6100
ASRock 970 Extreme3
XFX Pro 650W
4GB Of DDR3 RAM ( 2x2GB )
So , Will this components work together? Like will the motherboard be able to run that Processor and Vid Card with no problems? Will the Power Supply be able to run the PC with no problems/Max Load?
Thanks in Advance
ATI 6850
AMD FX-6100
ASRock 970 Extreme3
XFX Pro 650W
Thanks in Advance
