5.1 surround sound issues.
Hello all, I recently purchased the Logitech x-540 5.1 surround sound speakers and have been having issues with them. First I set the speaker configuration to 5.1 and only 3 of 5 speakers work as for some reason it doesn't detect the left and right speakers. If I set it to 7.1 all speakers work, but again no left right.
Now here is my question. My motherboard is the P8Z68-V Pro, with Realtek ALC892 8-Channel High Definition Audio CODEC onboard which has worked just fine up until now. Would I need a sound card in order to get the computer to use the left and right speakers as the left/right speakers and not side speakers? Playing music isn't a huge deal, but playing games is becoming a major problem... Could be a driver issue as well I guess..
And if I need a sound card, would this one work for my needs? http://www.amazon.com/ASUS-Channel-Sound-Card-XONAR_DG/dp/B0045JHJSS/ref=sr_1_1?ie=UTF8&qid=1348103168&sr=8-1&keywords=sound+card
This is probably a really idiotic question, but the audio has never really been an issue up until now. I tried playing around with some settings but nothing seems to have worked.
Thanks in advanced!
1 answer Last reply
More about surround sound issues
  1. ...So I solved my own problem in the end actually. It was a very stupid mistake as I noticed that this entire time I had the L/R input plugged into the wrong jack...
    Well, it took looking like an idiot in front of everyone here to fix my problem but I'm just happy I did not buy a sound card and finally fixed this problem :)
Sound Cards Speakers Components
