Can I have 2 wireless networks on 1 FiOS connection?
Last response: in Networking
You can. My Actiontec doesn't work with my Samsung wireless printer. I picked up a Linksys router and connected it through one of the Actiontec ethernet ports. I have two networks because of it.
Thanks for the reply. How did you connect your Linksys to the Actiontec? Did you connect the Linksys WAN to an Actiontec LAN?
I had the Actiontec LAN port 1 going ot the WAN port on my Linksys router and was using that as my gateway, with the Linksys then routing through the Actiontec.
Since I don't have FIOS TV (not available here in NH, Fairpoint now the ISP), I've since had my connection rewired from coax to cat5 and just plug the Linksys router directly into that and ditched the Actiontec box all together.
Either way, you'll can manage with 1 wireless network rather than 2, unless you wat to split up the traffic purposely.
Ask the community
