Solved
Will This Build Work?
This is my build that i have been looking at, i have found these parts... I will be crossfiring my GFX in future.
I want to know if this will work, if so how well?
Will it fit together?
Are any parts bad like motherboard or networking?
Will it be hard to set up, BIOS, putting together, installing windows with this particular build?
And what concerns me the most is the power supply? Will it run this? And will it allow for crossfire in future?
And will it run the latest games: BF3, Skyrim, Crisis ect?
Thanks For your time and help
PC Build From http://pccasegear.com
CASE____________NZXT Guardian 921RB Red LED $85.00
http://www.pccasegear.com/index.php?main_page=product_info&products_id=20064
MOTHERBOARD_____ASRock Z77 Extreme4-M Motherboard $145.00
http://www.pccasegear.com/index.php?main_page=product_info&cPath=138_711_1183&products_id=19866
CPU_____________Intel Core i5 2500K $229.00
http://www.pccasegear.com/index.php?main_page=product_info&cPath=187_346_1184&products_id=16531
MEMORY__________G.Skill Ripjaws X F3-12800CL9D-8GBXL (2x4GB) DDR3 $65.00
http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_912&products_id=16510
GFX CARD________HIS Radeon HD7850 2GB $265.00 (I WILL CROSSFIRE LATER)
http://www.pccasegear.com/index.php?main_page=product_info&products_id=19820
OPTICAL DRIVE___Pioneer DVR-219L DVDRW OEM $25.00
http://www.pccasegear.com/index.php?main_page=product_info&products_id=16397
HDD_____________Western Digital Green 1TB WD10EZRX $99.00
http://www.pccasegear.com/index.php?main_page=product_info&cPath=210_344&products_id=19780
POWER___________OCZ ModXStream Pro 700W Modular $99.00
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_535&products_id=12402
NETWORKING______ASUS PCE-N15 Wireless N PCIe Adaptor $45.00
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18067
OS______________Microsoft Windows 7 Home Premium 64bit with SP1 OEM $99.00
http://www.pccasegear.com/index.php?main_page=product_info&products_id=17003
$1156.00
I will also be crossfiring later, Screen, Keyboard and Mouse are already covered.
3 answers Last reply Best Answer
More about will build work
  1. Best answer
    yeah its all good , installing windows will be no harder than on any other system
    your psu will power your system bit its not powerful enough to crossfire 7850's I think a good recommendation would be a 1kw psu
  2. Yeah I just heard flashing BIOS can be hard to find the firmware... And I wont be crossfiring until probably next year so I could just get new power then.
    Anyway thanks for your help, I was fairly sure this would work apart from the power
  3. Best answer selected by General-NOH.
Homebuilt Build Systems
