Hi,
I'm in the process of building a computer that will need to handle (at least on medium-ish settings) games like Arma II, Diablo III, DCS: A-10C Warthog, BMS Falcon 4.0, etc. If it will handle those, it will probably handle anything. I need a little help double checking compatibility, and I'm very open to any suggestions that you folks might have.
Approximate Purchase Date: This week (would prefer to order everything today)
Budget Range: $1000 ish
System Usage from Most to Least Important: Gaming, ability to upgrade later to dual video cards & multiple monitors
Parts Not Required: Monitor, keyboard, mouse
Preferred Website(s) for Parts: newegg.com
Country: USA
Parts Preferences: Nvidia over AMD (unless there's a very good reason to go the other way), otherwise I don't know much about most computer hardware.
Overclocking: Maybe
SLI or Crossfire: Yes (Eventually; I'm trying to keep the price down for right now by sticking with just one video card.
Monitor Resolution: 1360 x 768
Additional Comments: As I mentioned earlier, I'd like this computer to have the capability to accept a SLI / Crossfire setup. I don't know if the parts I've selected are adequate for my purposes.
Here's what my wish list looks like right now. I would really appreciate it if somebody who is more experienced with computers than I am can double check everything for compatibility, and also for common sense... Do I need more motherboard? More power supply? More video card? Less anything? Have I selected any components that are known to be poor performers, or can I get a significant performance increase for relatively little increased cost?
This is just a list of items I put together... If you've got a good enough argument, I'm open to throwing it away entirely.
Case - COOLER MASTER HAF 932 Advanced RC-932-KKN5-G
Motherboard - ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Power Supply - OCZ ModXStream Pro 600W Modular High Performance Power Supply
CPU - Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
2 x Memory - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
GPU - EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16
HDD - Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Optic drive - SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM
Thanks in advance for any help you can give me!
Country: USA
Overclocking: Maybe
