Approximate Purchase Date: June 20-27
Budget Range: (e.g.: 0-1200) After Rebates
System Usage from Most to Least Important: Gaming
Parts Not Required: Monitor, CD/DVD drive
Preferred Website(s) for Parts: Newegg
Country: USA
Parts Preferences: None
Overclocking: Yes
SLI or Crossfire: No
Additional Comments: Content with the case I have, just in need of some advice on what to get
The setup I want:
-NZXT LEXA S LEXS (Case)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146060
-Wireless Adapter ( I know it isn't the best, but it is all that I need)
http://www.newegg.com/Product/Product.aspx?Item=N82E16833425002
-OCZ ZT Series 650W Fully-Modular 80PLUS Bronze High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341051
-Saitek Eclipse II Illuminated Keyboard (Once again, all I need)
http://www.newegg.com/Product/Product.aspx?Item=N82E16823175001
-Sunbeam FireLine MS-2011-BK-BL (Once again, all I need)
http://www.newegg.com/Product/Product.aspx?Item=N82E16826178003
-CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233170
-LOGISYS Computer ML12RD 12" 18 LED Super Bright Sunlight Stick (Not sure if this will be too bright for the case, suggestions please!)
http://www.newegg.com/Product/Product.aspx?Item=N82E16812551002
-Seagate Momentus XT ST750LX003 750GB 7200 RPM 32MB Cache 2.5" SATA 6.0Gb/s Solid State Hybrid Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148837
-Thermaltake WATER2.0 Performer (I know this isn't necessary but I am going for a sleek look on my computer, I feel like a fan is too large, especially from what I've heard about this case & the space between the fans & CPU HS)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106188
-HIS IceQ X Turbo H685QNT1GD Radeon HD 6850 + Windows 7 Pro (Combo deal)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.939602
-BIOSTAR TZ77XE3 + Intel i5 3570K 3.4 GHz
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.908217
So, good or bad? What do I ned or not need,
Country: USA
Overclocking: Yes
The setup I want:
