Pavilion dv7-2277cl Problems
Hello. I was hoping you guys could help me with a couple of problems I am having with my parents notebook.
1) The thing goes very slow. It loads everything slow, it lags when I am typing, and just sucks. This is less than a 3 year old laptop. I have yet to figure out where to start looking for a solution. First we found out the HDD failed, so we bought a SSD, and it is even slower now. Can it be the CPU fan not spinning or something else failing?
2) It gets very very hot. I have been on for 5 minutes and already it is making a loud noise. This I think it contributing to the slowness of it as I defragment and use CCleaner almost everyday.
No mater how many re installations of the OS I did, it was still the same.
1 answer Last reply
More about pavilion 2277cl problems
    first off you dont defrag an ssd you make it slower then it ws.if your using xp there a tool to aline the ssd for xp. you have to check the amount of ram in the laptop.if it less then 4 gig adding more ram will help. dust can clog the cpu fans. if your dad got a compressor use it to blow the dust out. if the unit out of warranty look to see if the fans are running if not you have to replace them.
Prebuilt Pavilion Systems
