I'm going to build a new pc soon but I got a little confused when it comes to the sound card. I own these speakers Creative Inspire T3030 which are 2.1 and I already have a sound card. A program from CPUID identifies the card exactly as Sound Blaster PCI (it's very old because I got it about 4-5 years ago). The MOBO i'm going to buy is the Asrock Socket 1155 Z77 Pro4 or the H77 Pro4/MVP which both have the same oboard sound: 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), Supports THX TruStudio.
Will the onboard sound be worse than the sound that my pc produces now with the old Sound Blaster PCI?
Should I buy the Asus Xonar DG or go with the onboard and not waste money?
Speakers:
http://support.creative.com/Products/ProductDetails.aspx
http://www.newegg.com/Product/Product.aspx?Item=N82E16836116007
MOBOs:
http://www.asrock.com/mb/overview.gr.asp?Model=Z77%20Pro4
http://www.asrock.com/mb/overview.gr.asp?Model=H77%20Pro4/MVP
ASUS Xonar DG:
http://www.asus.com/Multimedia/Audio_Cards/Xonar_DG/
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020&Tpk=xonar%20dg
Speakers:
MOBOs:
ASUS Xonar DG:
