I honestly cannot figure out what is wrong with my system. Here's how it all started,
I'm playing TERA when suddenly my computer just turns off and I tried restarting but got 6 post beeps.
I googled what that meant and it said that it was the keyboard controller. I was instructed to try different keyboards but it didn't work. Thus, I concluded that my motherboard had fried.
I purchased a motherboard from eBay and when it arrived, the system would simply not show video at all. It would start and stay on forever with no video loading. So I assumed the motherboard was DoA and returned it.
I bought ANOTHER motherboard from eBay and THIS time, my computer won't stay on for more than a few seconds before turning off. The video works because I can get to the post screen but it never stays on for more than a few seconds. Occasionally, it turns itself on and off but ultimately turns off.
The POST and BIOS are loading but they are shut off each and every single time by the computer.
My google search indicates that it would be a faulty power supply but my question is, my power supply never failed on all of those other tests and it was the motherboard each time....is it really my power supply this time? I do have an extra power supply on hand that I could try but it would be an extreme hassle to remove and replace the Alienware PSU.
I use an Alienware J560M motherboard along with an Alienware 1100 Watt PSU.
Yes, they're Alienware parts but the only reason I'm using them is because I bought the barebones case and AlienFX doesn't work if it is not an Alienware motherboard
