Ok, i built a budget computer for my friend to play Diablo 3. With looking at system requirements and help from the internet community i came with this build.
Windows 7 Home 64-bit
BIOSTAR A780L3B AM3 AMD 760G Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138329
LOGISYS Computer CS368RB Red & Black Steel ATX Mid Tower Computer Case 480W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811148062
XFX HD-667X-ZNFQ Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150576
AMD Phenom II X2 560 Black Edition Callisto 3.3GHz Socket AM3 80W Dual-Core Desktop Processor HDZ560WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103887
CORSAIR 4GB 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMV4GX3M1A1333C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145322
Used a 640gb Samsung HDD from a previous computer but also order a 320GB WD Caviar Blue
Now everything went well building it, downloaded all windows updates, updated BIOS, Downloaded the Catalyst suite for the Radeon card, and downloaded Diablo 3 to play. Now by specs the game should run on medium settings decently, but it wont. Everything turned down to its lowest settings the game stutters and slows down. Enemy mobs the game slows down to almost a halt... In Act 3 where theirs mortar fire around you slows it down alot. But if theirs not too much going on it will go from slow stuttering to catching up fast. Only for a split second tho.... This is a pulling my hair out moment lol Spec's say yes but game says no... Also changed the case's 480w PSU to an older 650w PSU and no change... Anyone got advice or see something ive missed?
Also i dont believe its the servers b/c for one this has been happening since the game came out. and second my personal computer runs this beautifully. Core i7-920 9GB RAM GTX 260 Win7 64-bit.
