Sign-in / Sign-up
Solved
Which power supply is best fit to my PC?
  • Power Supplies
  • Motherboards
  • Components
  • Product
Last response: in Components
September 23, 2012 9:00:08 PM
Intel Core 2 Quad Q8300
IPIBL-LB (Benicia) motherboard
8GB memory
300 power supply
here is a problem!!!!
i want buy HD 7850 graphic card and it require 500W or higher
so which power supply is good?
by the way, i want a quiet and well heat dissipation power supply
More about : power supply fit
September 23, 2012 9:06:45 PM
Antec, Corsair, Seasonic, Xfx, PC power and cooling Just pick a good reliable brand like the ones I listed and you won't be disappointed.
m
l
a b ) Power supply
a b V Motherboard
September 23, 2012 9:08:10 PM
XFX Pro 550w Core is an excellent model with the wattage you are looking to move up to.
m
l
a b ) Power supply
a b V Motherboard
September 23, 2012 9:11:49 PM
where you buying from and whats your price
m
l
September 25, 2012 12:32:26 AM
Best answer selected by shadowckx.
m
l
