Help With A Low 3.3 Volt Rail
Hey everyone, I am new here but today I experienced some issues I need some help with. I have a my work computer and today it started to act up really bad. It would not turn on, i restart it, still nothing and then a few more tries later it will turn on. I also want to note I have NEVER overclocked anything.
I went and looked at the voltage rails and I have a low 3.3 volt rail.
Vcore @1.356
3 volt lead is between 3.000v and 2.952v
5 volt lead is @ 5.956
12 Volt lead is at 12.180
Anyway in the bios is it popping up telling me that the 3.3 is outta spec. I installed AI II and it just told me that I have a low 3.3 rail as well. Would this be the issues for the problem I am having? Again this is my work desktop and I cannot afford to have downtime. What are the risks of running it like this until I can get it fixed?
My power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018 //
My Motherboard
Asus M4A88T-V EVO/USB3
Other Mis Items that Might help
Phenom II 965 @ Stock Speed
8GB Gskill Memory @ Stock Speed
AMD 6850 @Stock Speed
2 answers Last reply
More about help volt rail
  1. try this it's free work with 32 or 64 bits os and see what is the voltage that been report with the sensors http://www.hwinfo.com/
  2. software monitoring is useless only way to be sure is to actually measure the voltage with a multimeeter
Power Supplies Components Product
