Hello guys,
I appreciate every help i can get! I would like to upgrade my old system cause it started to suck at new games. Plan to play in 1080p, maybe do some other stuff, and a bit programming (started studying).
And would like to play all new and upcoming games on ultra +30fps if possible to not change my new build for about 2 years. So thank you forwards for your answers and sorry for my English I'm from Austria.
Proc: Phenom II x3 720BE
GPU: Sapphire Radeon HD 3870
RAM: 4GB DDR2 800Mhz Corsair
MOBO: Gigabyte MA-790X-UD3P
This will stay the same:
CASE: Antec 900
PSU: Corsair VX550W
HDD: Western Digital 500GB SATA II
Monitor? Samsung S24A350HS(planning to buy this under 200 € better suggestions?)
What i was thinking:
CPU: Intel Core i5-3570K Prozessor (3,4GHz, 6MB Cache, Sockel 1155) boxed
or
Intel Core i7-3770K Prozessor (3,5GHz, L3 Cache, Sockel 1155)
MOBO: ASRock Z77 Extreme4 Sockel 1155 Mainboard (ATX, Intel Z77, 4x DDR3, DVI-D, HDMI, 4x SATA III, 2x USB 3.0)
or
Gigabyte GA-Z77-D3H Sockel 1155 Mainboard (ATX, 4x DDR3 Speicher, HDMI, DVI-D, 2x SATA III, 4x USB 3.0)
RAM: I don't know if I get a nice boost with 2133mhz and 1866 mhz rams or are these just fine:
Corsair Vengeance (PC1600, 8GB, CL9) DDR3-RAM Kit 2x4gb kit
GPU: Is really hard to decide what card is good enough for everything but should not cost alot money.
I've been looking these two cards:
Zotac NVIDIA GeForce GTX 560 Ti 448 cores (PCI-e, 1280MB DDR3 Speicher, Dual-DVI, HDMI DisplayPort)
or
Sapphire ATI HD 7850 OC Grafikkarte 2GB (PCI-e, GDDR5 Speicher, HDMI, DVI, 2x mini-DP, 1 GPU)
I would like to have ivy bridge more than sandy bridge just because of the new tehnology, and alot of promises. Please help me to get nice 4 components for under 700€! And a suggestions for Monitor would be fine too if you have time. Thanks forwards!
Btw. I am buying at www.amazon.de !
CASE: Antec 900
PSU: Corsair VX550W
or
or
or
