Updating System - Compatibility - HELP
Ok Hello everyone,
Already gotten some great advice around Tom´s Hardware, but recently my budget changed so I had to make some changes to what I already thought I was going to do.
I´m buying/ordering most parts for this build around 9-16 June, so I need help with compatibility advices.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01127384&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3459837&aoid=35252
I have a HP M 8150 desktop, and it´s gpu stopped working, so I´m going to update the system and fix the problem.
(I was going for a complete rebuild but my budget changed so I had to make some changes)
Parts I´m buying:
- GPU - EVGA GTX 560 ti
- Motherboard - Asus P5G41T-M LX3 Motherboard
- Case - Haf 922 or Antec 900
- CPU cooler - Corsair H60
- PSU - Corsair CMPSU-500CXV2UK Builder Series CX500V2
- Ram - haven´t though about it yet so not a big deal at this stage. but overall 8Gb
- OS - Windows 7 student or.... windows 8 student (if there is one.)
Notes:
I´m keeping the Q6600 that my desktop has to save money, and with the water cooling, overclock it to around 3,0Ghz, so that it doesn´t bottleneck anything.
Please have in mind I don´t know ...anything about overclocking.. so I´ll just make it as i go along.
I intend to keep most of my other computer parts, optical drives, Hard drives etc.. all parts except the ones I´m buying.
Questions:
-Are the parts I picked compatible with the existing ones in my "prebuild" desktop?
- Does anyone here have the student edition of the windows 7? is it equal to the normal 7? any drawbacks?
- Will the corsair H60, keep my processor cool, if overclocked to 3.0 Ghz?
- What other case sugestions do you advice, or are the ones I choose good? my 2 most important aspects are size (enough to fit the Water Cooling) and price (this being the most important)
- Is the motherboard i choose good for overclocking/ is it good overall?
-I did some PSU calculations and I believe 500W is ok, whats your opinion?
Sorry for the long thread everyone, but this is the first time I build my computer so a lot of doubts, questions are going on my head.
Thanks everyone for the replys in advance.
7 answers Last reply
More about updating system compatibility help
  1. If you're going to go through this build - it's pretty stupid to salvage anything from it. The Q6600 was a good CPU in its' heyday but you should just drop your plans and start completely from scratch. The problem with prebuilt systems is that they're prebuilt - they use a lot of junk hardware, outdated components and non standard form factors. Even if you manage to successfully get it working, that CPU will still be a bottleneck when paired with any modern GPU due to slow RAM speeds and things of that nature. You're honestly better off building a completely new system than trying to salvage anything.
  2. I agree with g-unit, it isn't intelligent to use the same ram/cpu. You will limit yourself tremendously.
  3. I´m not going to use the same ram, I´ll buy new ram, now I have 2Gb DDR2 , I´m getting 8Gb DDR3, so the only thing I´ll be using is the same CPU, I´m a bit of noob so I guess that this will fix ram speeds...?
    I agree also with you (g-unit and eggbrook) when you say that it´s a old cpu, but a need a new system, and my budget is a bit low. So I´m keeping the cpu, overclock it, and since the water cooler has a 1155 socket, save some euros and in about a year swap both the motherboard and the CPu for a ivy bridge I7...
  4. So for now, I´ll save a few hundred euros and keep the Cpu, because a 1155 Motherboard will cost around (100-150€) and a i5-i7 cpu (150 - 250€), and latter upgrade, and then it will have all new components.
    Regarding HDD and optical drives, if it is a slowing factor, since they are not as costly I could upgrade them right now and get new ones..
    So regarding my initial questions can someone please help me out? I realy need to get this system sorted out to start buying/ordering parts.
    Thanks!
    Thanks!
    The HDD and optical drives are something that you can definitely reuse as long as they fit your new case's drive bays.
    I'm still not entirely sure that's a good idea - the thing with water cooling is that it's way too much risk for not a lot of payoff and the wrong cooler - if it leaks can really damage your system and most manufacturer's warranties don't cover water damage. Either you build from scratch or you reuse your existing system with a couple of minor upgrades. I honestly don't think that this plan would be systematically feasible unless you want to have some major bottlenecks in the CPU and other areas.
  6. There is a low chance it will leak. Like 20% chance or something, but I agree; WC is only for extreme enthusiasts who like to test its limits.
  7. Sorry for the late reply, well in that case I´ll change to a air cooler, and avoid problems.
    Regarding the Q6600 creating a bottleneck, I am now a bit confused, seen some videos on youtube thought that it would run great, just searched on youtube for "Q6600 GTX560ti" and found some crysis 2/battlefield3 gameplay videos that look amazing....
New Build Compatibility Systems Product
