Solved
Is this enough power for 500watts?
i have a
-evga geforce 550 ti 2gb
-ASUS M5A99X Evo - AM3+ - 990X - SATA 6Gbps and USB 3.0 - ATX DDR3 2133 Motherboards
-amd phenom ii x4 965
Is this enough power? if it is will it be good for the next 4-8 years without dieting on me or break anything.
7 answers Last reply Best Answer
More about power 500watts
  1. 500 watts is plenty for that system, but not all watts are created equal.
    Be sure to get a quality power supply. A good 400w would probably suffice, but I would go with 500w just to have some headroom.
  2. im considering getting Cooler Master eXtreme Power Plus 500w Power Supply. is this good enough for my GPU, MOBO, and CPU?
  3. Cooler master doesn't do well in testing.
    Try Something like:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
  4. what if i said i already bought it. would it still be ok? like will last me awhile without breaking anything?
  5. Best answer
    Then just run it.
    http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-500-W-Power-Supply-Review/728/10
    "We can’t recommend this power supply, however if you are really on a budget this may be an option until you have money to buy a decent power supply for your PC."
  6. Best answer selected by shadow2895.
  7. ty for everything
Power Supplies Power Components Product
