(urgent)Will a PCI-e 3.0 card work on my gateway TBG01 motherboard?
Related ressources
- Does SLI work if you have a motherboard with a PCI-E slot 2.0 x16 and 3.0 x16? - Forum
- Will PCIe 3.0 card work on PCIe 2.1 motherboard ? - Forum
- Will PCI-E 2.0 card work in 3.0 slot if - Forum
- Can i install a pci-e x16 3.0 graphics card in a pci-e x16 2.0 motherboard ?? - Forum
- HELP!! Will 3.0 PCI-e Graphic Card work on a 1.0 PCI-e Slot? - Forum
Related ressources:
- ForumHow does pci-e 2.0 and 3.0 work ?
- ForumWill a PCIe v 3.0 vid card work in a v1.0a MB?
- ForumWill a PCIe 3.0 x16 card work in a PCIe 2.0 x16 slot?
- ForumWill a PCIe 1.0 card work in a 3.0 slot?
- ForumWill a PCIe 2.0 Graphics Card Work in a PCIe 3.0 Slot?
- ForumGateway FX6840-01e Motherboard Upgrade
- ForumPCI-E 3.0 Graphics Card on a 1366 Motherboard with PCI-E 2.0
- ForumPCIe 2.0 motherboard with PCIe 3.0 graphics card
- ForumWill a cpu that's only compatible with pcie 2.0 run a 3.0 card ?
- ForumCan pcie 2.0x16 gpu can work with 3.0 x16 slot with core 3rd gen i3 processer on
- ForumGigabyte z77-d3h motherboard pcie 3.0 16x not working
- ForumWill PCI-E 2.0 x16 Mobo supports PCI-E 3.0 X 16 Graphic Card ???
- ForumAsus 660ti DCU2 SLI, 680 DCU2 TOP or 7970 Matrix
- More resources
once again i dont know much at all on this stuff
