W winstonconner Honorable May 30, 2012 19 0 10,510 Jun 1, 2012 #1 I'm on a $600 budget but want to build a good, gaming computer, help? Undecided whether or not I want to overclock. Also need a good monitor for under $200 (Not including monitor in budget)
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Jun 1, 2012 #2 http://pcpartpicker.com/p/9fuo its 700 dollars if i include the OS. rather you spend more money on the computer than on the monitor. this will play most games at high settings Upvote 0 Downvote
W winstonconner Honorable May 30, 2012 19 0 10,510 Jun 1, 2012 #3 Thanks dude! This helps alot! Did you make this list yourself? Upvote 0 Downvote
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Jun 1, 2012 #4 yep i make all my lists there Upvote 0 Downvote
