Will this PSU power GTX 660Ti?
I just got my 660ti and this psu but haven't opened it yet because i am not sure if this PSU will be able to power the card.
Its an OCZ Stealthstream 600w- http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
These are the parts i currently have and I am not sure if this case is the best choice for me recommendations will be awesome.
CPU- Intel Core I5 3570k 189.99
MOBO- AS Rock z77 extreme 4 1155 ATX- 84.99
GPU-EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB 192-bit GDDR5- 289.99
PSU- OCZ StealthXStream OCZ600SXS 600W ATX12V / EPS12V SLI Ready Active PFC Power Supply- 39.99
RAM- CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model - 49.99
CASE- Cooler Master HAF912 ATX Mid Tower Case- 54.99
HD- Seagate barracuda 1tb 7200RPM SATA 6.0GB/s
3 answers Last reply
More about will power 660ti
  1. Your choice of case is excellent, it's a great gaming case for the price.
    However, there's a few things I would like you to change; PSU and GPU.
    XFX Core Edition 550w PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013&Tpk=XFX%20550
    Sapphire Radeon HD7950 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
    GTX660 Ti isn't worth the cost considering how badly the memory interface bottlenecks it. Once you crank up settings such as MSAA or AF, your FPS will drop DRAMATICALLY. http://www.tomshardware.com/reviews/geforce-gtx-660-ti-memory-bandwidth-anti-aliasing,3283-11.html
    Those benches are a great example.
  2. Ill get either that PSU or the corsair cx500 or cx600, and abotut the graphics, I got that graphics instead of the 7950 because it came with a free borderlands 2 download.
  3. Ahh, understandable :) $60 value for free...that's hard to resist, I admit.
    Actually, the CX500 would be a better value for you. The GTX660 Ti doesn't use much power AT ALL so you can feel comfortable with overclocking if you go with a CX500 as well.
Power Supplies Components Product
