Solved
Which Power Supply Do I Need/Want?
Last response: in Components
I am organizing the parts for my dream gaming pc. I know nothing about power supplies or how to decide which wattage is ideal. I plan on overclocking as I am also buying a watercooled case. Here are the parts I plan on buying, feel free to suggest better ones :D
ASUS Maximus V EXTREME LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
EVGA 02G-P4-2680-KR GeForce GTX 680 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000
BX80637I73770K
Refurbished: Creative Sound Blaster X-Fi Titanium Fatal1ty Professional 70SB088600002-8 7.1 Channels PCI Express x1 Interface Sound Card
Z-Machine LQ1000 Water Cooled Enclosure
Thanks SOO MUCH guys. This is my first build.
More about : power supply
Related ressources
mocchan said:
Unless you're planning to Quad SLI your 680's, there's no need to get a 1000w PSU :)
650w will run any Single-GPU card on the market with an OC'd CPU.
Thanks so much man, I dedicate my future power supply to you :p
mocchan said:
Corsair TX850V2 PSU if you're wanting to SLI GTX680's
Seasonic X Series 650w PSU if you just want a single GTX680 :)
hmmm is it possible to get a modular psu that will work well with either one OR two 680s?
one more question while i have such an expert :p
i am water cooling, using a DD12V-D5 Pump Variable Speed by Laing. it says it uses 4 pin molex connectors, I dont see any on my future motherboard, Asus Maximus V Extreme, is that the same as a four pin fan header? it has plenty of those and I believe they are 12V. or can a molex connector or two, or three preferrably, be found on a psu? thanks soooo much
Very nice choice of pump!
Anyways, Molex is a plug that is attached to your PSU, not motherboard, so you shouldn't worry one bit. From the looks of it, the 850w Seasonic unit I listed comes with 4 Molex plugs :)
Wow you sure know your stuff man :D  I appreciate it very much, I have half a mind to add you or whatever as I undoubtedly will need help along the line and you are smart :D
mocchan said:
:)  This is what I would personally purchase...80+ GOLD and it's fully modular for the price of $109.99; quite a steal!
Hi - I agree with moochan on Seasonic X650 (i just installed mine 3 days ago), but for the next 24 hrs($40 promo code expires) you can get
the Seasonic X750 Gold for $109.99 at
Thanx
Tom
Ask the community
