Will a amd fx work with Asrock 870 extreme 3 r2.0
hey guys, im making a medium sized build not to expensive an i have a Asrock 870 extreme 3 r2.0 lying around, it very difficult to find a phenom processor now so i was wondering if a amd fx 4100 cpu will be compatible? if not what woould you guys suggest, ? thanks guys
ps i dont really want to buy another mobo .. thnkas
3 answers Last reply
More about will work asrock extreme
    i live in new Zealand by the way
  2. http://www.asrock.com/mb/overview.asp?Model=870%20Extreme3%20R2.0
    If that is your motherboard, then yes it is AM3+ and even 8 core ready, so it will support the fx 4100 without a problem.
  3. thanks. much appreciated
CPUs ASrock AMD
