Tom's Hardware > Forum > Digital Camera > Digital Camera General > Camera having problems - is it the camera or memory card?
Forum Digital Camera : Digital Camera General - Camera having problems - is it the camera or memory card?
Archived from groups: rec.photo.digital (More info?)
Recently my digital camera (Olympus, lower end and about 4 years old)
started acting up. It takes pictures, but then when I check the
listing, it may only have one or two of the actual pictures there. So
I'll take ten pictures, and maybe have a couple that really show up.
I've tried reformatting the camera's drive and so on, and nothing seems
to work. I hate to go buy a new memory card and then discover it was
the camera and be stuck with a card I don't need.
I use Macintosh.
Thank you.
Sponsored Links
> I use Macintosh.
> Thank you.
You shore don't give much information to go on.
I have an Olympus D-510 that uses smartmedia.
My symptom was random failure to read the card,
frequent demands to reformat then the format failed.
Turned out that my problem was lack of solder on some
of the pins of the smartmedia socket. took years for
the pins to fatigue and corrode enough to quit working.
If it's smartmedia, the first thing I'd try is cleaning.
Use isopropyl alcohol to clean the card contacts.
I took some heavy bond paper wrapped around a thin sheet of
plastic and doused with alcohol to clean the socket. Measure the
thickness of the cleaning assembly to be slightly less than
the thickness of your card so you don't spring the contacts.
I also cleaned my card reader. If one is contaminated, the other
probably is too.
I still have not figured out exactly what a camera does about
bad blocks on a smartmedia card. My mp3 player can reformat
a card and mark the bad blocks. But the camera may or may not undo
that when you reformat in the camera. Maybe someone can chime in here
with the true answer.
If it's not smartmedia...never mind.
Precise questions get better answers.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Reply to Mike
> I use Macintosh.
> Thank you.
Try cleaning the contacts on the card. Rubbing gently with a clean eraser should do the
job. And blow out the card slot with canned air. A little dirt on low-voltage contacts
can cause problems.
Reply to Marvin
There are 1264 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
