Problem with home built; Think it's the Hardware
So the way my problem goes is the following. If my computer is on, I can't let it go into hibernation else it won't wake back up.
If I shut down my computer properly, then when it starts up, it just goes to a screen with a blinking underscore.
Finally, on second, usually third start up, it goes to a screen with the selection:
-System Resume
-Delete restoration data
The only way I can now successfully start my computer is to delete restoration data.
Any thoughts?
1 answer Last reply
More about problem home built hardware
  1. check that the bios of the mb is up to date there a lot of cpu and memory update for mb.
Homebuilt Hardware Hibernation Computer Systems
