Closed
Power Supply cables to MSI N610 GT or not
  • Power Supplies
  • Graphics Cards
  • Cable
  • MSI
  • Components
Last response: in Components
September 28, 2012 7:10:23 AM
Does MSI N610 GT need any PCIE 6-pin cables connected to it? Some people told me that it's powered through the PCI-E x16 slot and those cables are not needed.
My Graphics card spec: http://www.geforce.com/hardware/desktop-gpus/geforce-gt...
More about : power supply cables msi n610
a c 76 ) Power supply
a b U Graphics card
September 28, 2012 7:22:55 AM
No.
It maxes out at 29W, so there wouldn't ever be a need for a separate 6 pin connector for it anyway.
Score
September 28, 2012 9:21:39 AM
How much power would it need to have if a 6 pin connector is needed?
Score
Best solution
a b U Graphics card
September 28, 2012 5:01:06 PM
A PCIe 2.1 and above x16 slot can provide 150W, but most GPU manufactures stick with the 1.0 spec of 75W, to not break compatibility.
In any case, any card that draws less than 75W will never have a need for a PCIe power connector.
September 29, 2012 5:37:45 AM
Best answer selected by whsim.
Score
September 29, 2012 5:46:01 AM
If i go with Geforce 630 ( http://www.geforce.com/hardware/desktop-gpus/geforce-gt... ) which its max graphics card power is 65 W does it mean that this card also doesn't need that 6 pin connector?
Score
a b U Graphics card
September 29, 2012 5:48:22 AM
As far as I know, and can tell, that's correct.
Score
September 29, 2012 5:50:45 AM
If my PSU is 450 W and the graphics card requirement power is 300W . can my PSU support it?
Score
a b U Graphics card
September 29, 2012 5:52:59 AM
Oh yeah. Even a "bad" 450W PSU should be ok with the GT 630. In reality, it won't ever really pull 65W unless you force it to by stress testing it.
Score
September 29, 2012 5:59:59 AM
I'm ony afraid of that my CPU will be damaged if the power is not enough for the whole system
Score
a b U Graphics card
September 29, 2012 6:06:18 AM
It won't be, don't worry about that.
The absolute worst case scenario is that the PSU literally blows up and takes the GPU and/or motherboard with it, but that won't happen with a GT 630. If you were talking about using something like a GTX 680, then you might have a problem, but absolutely not with a GT 630.
Score
a b ) Power supply
a c 274 U Graphics card
September 29, 2012 12:22:26 PM
This topic has been closed by Mousemonkey
Score
