The Corsair without doubt, though it won't be much of an upgrade on the power side, more of an stability upgrade i would say, and is without doubt more solid build and has higher quality components inside.
You may also want to consider some higher wattage models, just to be on the safe side in the future, one day you may want to add a high end gpu and you will have to change psu again.
