Well, I was planning on building my first computer (probably in about half a year, as I'm still saving up money) and wanted to know if the current plan is unbalanced.
Motherboard: Asus P8Z77-V Premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131850
CPU: i5 - 3570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
CPU Cooler: Spire TherMax Eclipse II
http://www.amazon.co.uk/Spire-TherMax-Eclipse-SP984B1-V2-Processor/dp/B003CMLPWA/ref=pd_sxp_f_pt
GPU: Asus GTX 680 Direct CUII
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121634
RAM: Corsair Vengance (2x8GB) (x2)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246
Power: Corsair 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
SSD: Crucial M4 256GB SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148443
HDD: Seagate Barracuda Green 2TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148681
So now the wonder is, will any of these parts be a limiting factor? Will any be too powerful? Off the bat, I'm sure you'll mention the motherboard and the ram. I'm fine with changing the motherboard, this one just seemed really nice, and I'd like to keep as much ram as possible, considering it's so cheap (relatively). This PC will be for gaming, which is why I chose the 3570 instead of the 3770. I'll probably overclock it and use the "Spire TherMax Eclipse II" Price isn't really an option, but I'd be stupid to say I don't want to keep it as cheap as possible while still getting stellar performance. Any help is greatly appreciated
P.S. I would have included a list from pcpartpicker (I still can if it would make it easier for you guys) but many of the parts I wanted to use weren't on there.
CPU: i5 - 3570K
Power: Corsair 750W
