First build review, advice and suggestions welcome
I’m building my first gaming PC and i wanted to know if the investment made in building the PC is good or not. I want the PC to have good longevity. I would like advice or suggestions on the components whether they are not good enough or are overkill and money can be saved.
CASE - Sharkoon T9 Gaming Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-SH&campaign=pcm/googleshopping
CPU - Intel i7 3770K
http://www.shop.bt.com/products/intel-core-i7-3770k-s1155-3-5ghz-8mb-7YXF.html
CPU Heatsink - Be Quiet! Dark Rock PRO
http://www.overclock.co.uk/product/Be-Quiet!-Dark-Rock-Pro-Dual-Fan-CPU-Cooler-AMD-AM3--AM2--Intel-1366--1155--1156--775_39931.html
Power Supply - 850W Corsair Pro Gold
http://www.amazon.co.uk/dp/B003QP417O/ref=asc_df_B003QP417O8142747?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B003QP417O
Graphics Card - NVIDIA GeForce GTX 670
http://www.overclockers.co.uk/showproduct.php?prodid=GX-164-MS&campaign=pcm/googleshopping
Motherboard - Asus P8Z77-V DELUXE (Intel Z77) - HDMI/DVI/DP
http://www.amazon.co.uk/dp/B007KZQE5I/ref=asc_df_B007KZQE5I8142747?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B007KZQE5I
RAM - Corsair 8GB
http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS&campaign=pcm/googleshopping
Hard Drive - 2 TB (2000 GB) SATA-III HDD 7200 RPM 64MB
http://www.advancetec.co.uk/acatalog/2TB-Seagate-ST32000542AS-Barracuda-SATA-II-5900rpm-32MB-Cache-HDD.html#a3464
I don't know much on PC's but I'm learning. I will gratefully appreciate all your guys input.
1 answer Last reply
More about first build review advice suggestions welcome
  1. I wouldn't get the i7-3770K for a gaming build. Save the money and go the i5-3570K route. You also don't specify if you want to OC or not. If you aren't going to OC, you don't need an unlocked CPU or an aftermarket HS.
    For the cooler, go with a Hyper 212 EVO, it's half the cost on the website you have listed. (If you plan to OC)
    You also don't need that large PSU. Try this one:
    http://www.amazon.co.uk/Corsair-CMPSU-650TXV2UK-Enthusiast-Series-Performance/dp/B004O0P9TO/ref=sr_1_1?s=computers&ie=UTF8&qid=1338668770&sr=1-1
New Build Systems
