Looking for any problems with this Build. Was asked by co-worker who wants to buy parts for son to build. He is either a Junior or Senior in HS. Use will be general purpose with some Gaming. Currently gaming on Xbox. The GPU I omitted in cost and go with the iGPU HD4000
and later upgrade to the 6870, or an 77xx.
Unsure of the Budget, but she did not blink (too hard) when I said about a Grand.
Here's My initiaL Cut:
Case ............... Thermaltake V9 BlacX ................. $113
Mother board .. BIOSTAR TZ77XE3 ...................... $100
CPU ................ Core i5-3570K ............................ $240
Ram................ G-Skill Ripjaws, DDR3-1600 CL8 .. $ 60
GPU ............... SAPPHIRE Radeon HD 6870 .......... $160
PSU ............... Carsair TX650 V2 650W ............... $90
SSD ............... Curcial 128 Gig SSD ..................... $124
HDD ............... Samsung 1TB F3 ......................... $109
HSF ............... Hyper 212 ................................... $ 30
KB & Mouse ... GearHead wireless.(From Big Lots). $ 25
Win 7 64 Bit OEM ................................................ $100
Total ................................................................... $991
Does not include Monitor and did not take off for MIRs ie HDD is currently only $80 wit MIR.
Links
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133182
MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138355
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Ram : http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Thanks.
Already has ground strap (She's in QA) - And you can bet he WILL wear it - LOL.
Links
Thanks.
