Basic info on my Device:
Netgear WGR614v9
Serial Number 1SV6927N1CDA
Purchased sometime in 2009
I was trying to upgrade to the latest firmware: 1.2.30
(as is listed here).
Well after the update, I apparently bricked my router. The power light blinks green continuously, and the check mark is a steady amber. I've tried resetting it multiple times/ways (even these fairly extreme ways.
When I went to the website for support I found a PDF document called: "NETGEAR router firmware recovery utility".
That document suggested using the Routers resource CD. However I no longer have that CD.
I figured I could download it from their site. Nope! .
According the Netgear's site, they don't allow you to download the software b/c everything you need is onboard the device and so one need only access the router to get the neccesary softare. Except b/c I bricked my router I can't access the software on the device .
Can anyone help me out with this awful catch-22 I've found my self in?
Any and all help will be greatly appreciated.
Thanks (in advance);
A (wireless-less) Bug
P.S. I did notice on the firmware upgrade page this note about the Smart Wizard 3.0 application
Note: This firmware will not work with the old CD’s (older than CD version 2.0) which don't have the Smart Wizard 3.0 application.
Netgear WGR614v9
