Hi.
I recently purchased a Corsair H80 liquid CPU cooler, after seeing that my i7 965 was idling at about 60C and hitting 80C under pressure (yikes!). After installing the H80 however, while the temperature decrease was appreciable, I'm concerned that it may still be smaller than what it rightly should have been. As of now, it idles around 45C and gets to about 55C under pressure, with no overclocking to speak of (3.2GHz), and with the radiator fans set to a speed at which they are obnoxiously loud. At first, it would go into the high 30s to low 40s at idle, but it's decided to stop that nonsense
My question is: Are the temperatures I'm getting now, after I put in the H80 where they should be? I'm seeing other people with H80s getting down to the mid 20s and low 30s.
System specs:
Intel core i7 965 Extreme @ 3.2GHz
12GB DDR3 RAM
EVGA X58 FTW3 Motherboard
2x Nvidia GeFore GTX 560Tis
(Side note, GPUs are running a little hot too, about 45C idle and 60C at load. Maybe they are connected?)
Thanks!
System specs:
12GB DDR3 RAM
Thanks!
