Will thease parts all work together?
Should I change the GPU to a XFX Double D HD-695X-CDFC Radeon HD 6950 2GB 256-bit?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549
33 answers Last reply
More about will thease parts work together
  1. IS this overkill. i want to play cod bf3 record it and then edit it.
    Case-Corsair Vengeance Series CC-9011016-WW
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811139014
    cpu-AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
    motherboard-ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
    RAM-G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
    power supply-CORSAIR Professional Series HX650 (CMPSU-650HX) 650W
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
    video card-EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
    hdd-SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
    This is my first pc build. and suggestions on changes? idk if the power supply is too much, but it has to be modular. will all these parts work together? should i get any cooling system i will not do any OC.
  2. It is all compatible but the CPU is not the best and the GPU is under powered for BF3. I suggest looking into Intel build based around I3 2100 and better GPU like GTX560 or HD6870 at minimum.
  3. budget?
    you won't need any extra cooling if you're not overclocking; that CPU is not bad, not great either. same can be said for the GPU.
  4. yes this pc can handle bf3 it just beats the min specs and it look like all the parts will work i am not going to recommend any changes be cause its a decent pc i know alot of people will recommend changes. and you will not be able to play on a high setting... unless you wanna pay more for better GPU.. and maybe better cpu like intel but that's a good chip there....
  5. You can use this as well and http://www.tomshardware.com/forum/261222-31-build-advice and post in the system section.
  6. I would recommend a 45nm Phenom II X4 C3 stepping CPU with an unlocked multiplier over the FX series.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
    Only $120 for the CPU and still a few decent AM3 mobos available on the net.
    I run my C3 Phenom II x4 @ 3.6-3.8ghz with a cheap Rosewill heatsink and it plays GTA IV, BC2 easily with many other tasks running in the background without issue. My GTX460 is my primary limitaiton when gaming, GTA IV will run at 45-55fps using only 75% of the CPU.
  7. I have a few suggestions for you -
    1) I'm sure a 550w PSU would be more than enough for you..it'll save you some cash as well.
    2) Different GPU. Preferably a 6850, GTX560, or 6870
  8. I would recommend you get this GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814121419 and this PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095 SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply it will even out the cost and give you better GPU
  9. Approximate Purchase Date: july
    Budget Range: $600-$800
    System Usage from Most to Least Important:gaming(bf3, cod, recording, editing)
    Parts Not Required: keyboard, mouse, monitor, speakers
    Preferred Website(s) for Parts: newegg or amazon(if amazon prime preferably)
    Country:usa
    Parts Preferences:no new to this i am not very knowledgeable
    Overclocking: no
    SLI or Crossfire: no
    Monitor Resolution: 1920x1080, 1920x1200 something high
    Additional Comments: i would like to use this case Corsair Vengeance Series
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811139013
    I want a modular power supply
  10. Try this
    Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
    Model #:Three Hundred Illusi
    Item #:N82E16811129066
    Return Policy:Limited Replacement Only Return Policy
    In Stock
    Mail in Rebate
    $69.99 -$10.00 Instant $59.99
    Update
    Model #:M5A97
    Item #:N82E16813131767
    Return Policy:Standard Return Policy
    In Stock
    $99.99 -$5.00 Instant $94.99
    Update
    SAPPHIRE Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card (100314-3L )
    Model #:100314-3L
    Item #:N82E16814102948
    Return Policy:VGA Standard Return Policy
    In Stock
    Mail in Rebate Card
    $179.99 -$20.00 Instant $159.99
    Update
    Model #:M12II 620 Bronze
    Item #:N82E16817151095
    In Stock
    $124.99 -$35.00 Instant $89.99
    Update
    AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor FD6100WMGUSBX
    Model #:FD6100WMGUSBX
    Item #:N82E16819103962
    Return Policy:CPU Replacement Only Return Policy
    In Stock
    $139.99 $139.99
    Update
    G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
    Model #:F3-12800CL9D-8GBRL
    Item #:N82E16820231314
    Return Policy:Memory Standard Return Policy
    In Stock
    $46.99 $46.99
    Update
    SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    Model #:HD103SJ
    Item #:N82E16822152185
    In Stock
    $139.99 -$30.00 Instant $219.98
    Subtotal: $811.92
  11. I would recommend a 45nm Phenom II X4 C3 stepping CPU with an unlocked multiplier over the FX series.
    http://www.newegg.com/Product/Prod [...] 6819103727
  12. I would have to agree for the most part of what everyone else is saying. The build is decent, and here are a few suggestions to make it better.
    i) The PSU is really good, but you can save some money for still getting a good solid PSU, like...
    600W+ PSUs:http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044 http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
    Bare Min PSUs: http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
    ii) The case is cool and all but I would look at something <$100(considering the budget), like...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 http://www.newegg.com/Product/Product.aspx?Item=N82E16811146081 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066 http://www.newegg.com/Product/Product.aspx?Item=N82E16811108407 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196 http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
    iii) with money saved spend more on a GPU or CPU. GPUs are getting cheaper since a new line of GPUs just came out. For gaming and recording and video editing, I would suggest the next step up is an Intel CPU. If not overclocking, try for an i5-2400 or even maybe an i3-2120. They are a generation old but still rock solid and cheaper than the new Ivy Bridge. The steps up in GPU are HD 6850, then the HD 6870, next GTX 560 Ti, and then the HD 6950, and HD 6970/GTX 570. Ive seen an HD 6950 for $200 which is a really good deal. Check out these for more questions...
    GPUs http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
    CPUs http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106-5.html
  13. Try this it's way better build and GPU PCPartPicker part list / Price breakdown by merchant / Benchmarks
    CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($109.99 @ Newegg)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.90 @ NCIX US)
    Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($84.99 @ Amazon)
    Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1333 Memory ($43.99 @ Newegg)
    Hard Drive: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($87.99 @ NCIX US)
    Video Card: Asus Radeon HD 7850 2GB Video Card ($249.99 @ Amazon)
    Case: Rosewill CHALLENGER ATX Mid Tower Case ($49.99 @ Newegg)
    Power Supply: SeaSonic 620W ATX12V / EPS12V Power Supply ($86.99 @ Newegg)
    Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.97 @ Newegg)
    Total: $768.80
    (Prices include shipping and discounts when available.)
    (Generated by PCPartPicker 2012-06-02 00:24 EDT-0400)
  14. You might want to jump on over to the Systems > New Build section of the THG forums where they handle about a couple dozen of these requests per day.
    And they are more in tune with current prices, sales and combo deals.
  15. PCPartPicker part list: http://pcpartpicker.com/p/9jGK
    Price breakdown by merchant: http://pcpartpicker.com/p/9jGK/by_merchant/
    Benchmarks: http://pcpartpicker.com/p/9jGK/benchmarks/
    CPU: Intel Core i3-2120 3.3GHz Dual-Core Processor ($120.68 @ NCIX US)
    Motherboard: ASRock Z68 PRO3 GEN3 ATX LGA1155 Motherboard ($104.99 @ Newegg)
    Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1066 Memory ($41.99 @ Newegg)
    Hard Drive: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($87.99 @ NCIX US)
    Video Card: MSI Radeon HD 7850 2GB Video Card ($259.99 @ NCIX US)
    Case: NZXT Apollo Black NP ATX Mid Tower Case ($67.98 @ Newegg)
    Power Supply: PC Power & Cooling 600W ATX12V Power Supply ($66.79 @ NCIX US)
    Total: $775.38
    (Generated by PCPartPicker 2012-06-02 04:59 EDT-0400)
  16. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  17. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  18. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  19. I am looking for a gaming pc to play battlefield 3, call of duty and recording. I have a budget of $800 max(if you could make it for less that is preferred.
    is this good?
    https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=14671869
  20. You are on a tight budget, spending so much on a case would hurt more crucial (performing) parts. ;)
    For instance, you can get a Corsair 300R for 80 bucks, that's 60$ more to spent on a better GPU/CPU or even an SSD.
  21. Nice case!
  22. Corsair Carbide Series 300R Black Steel / Plastic ATX Mid Tower Computer Case - $79.99
    Western Digital Caviar Blue WD10EALX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive - $99.99
    SAPPHIRE Radeon HD 7850 OC 2GB - $259.99
    (including AMD Gift - Dirt SHOWDOWN Gift Coupon)
    G.SKILL Ripjaws Series 8GB (2 x 4GB) - $46.99
    ASRock Z77 Pro4 LGA 1155 Intel Z77 - $119.99
    Intel Core i5-3570K Ivy Bridge 3.4GHz - $239.99
    (incl. Newegg Promotional Gift Card - $15.00)
    CORSAIR Builder Series CX500 V2 500W 59.99$
    = $906.93
    You could shave off 20$ by going i5 2500k and some more by using a cheaper case (like a Zalman Z9 plus for 50 bucks) or a slower GPU and propably ~20$ if you buy a refurbished HDD instead of a new one.
  23. I will use it to play battlefield 3, Call of duty, record and do video editing.I already have a 1tb HDD. Any changes to it I am at the max of my budget right now.
    Thanks
    GPU-SAPPHIRERadeon HD 7850 OC 2GB 256-bit GDDR5
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102984
    CPU-AMD FX-8120 Zambezi 3.1GHz Socket AM3+ 125W Eight-Core Desktop Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103961
    Motherboard-ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
    case-Corsair Carbide Series 300R Black Steel / Plastic ATX Mid Tower Computer Case
    ram-Kingston HyperX Blu 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820104262
    power supply-OCZ ModXStream Pro 700W Modular High Performance Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
    dvd-ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
  24. Write the spec names
  25. Hi max, those parts look fine and I don't see any issues
  26. Do you think the GPU is a good value?
  27. It's a good setup from what I can see.
  28. 60Gb will be tight very shortly after build, with win7 bf3 and some small programs (most on another drive) i'm at 80GB, BF3 is huge, and will be huger when the next dlc comes out (27GB at the moment)
    so do not expect to put Bf3 on your SSD
    shop around for the SSD as these http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442 are a lot cheaper in the UK, £85 for 128, and its normally 1:1 £:$ other than that you are good to go. I'd generally suggest crucial over force as there have been fewer reports of problems.
  29. Its about the same computer I have, and its awesome. Enjoy it!
  30. This topic has been moved from the section Video Games to section Systems by Mousemonkey
  31. This topic has been moved from the section Video Games to section Systems by Mousemonkey
  32. This next topics has been merged by Mousemonkey
    Is this a good enough computer to play battlefield 3?
    Gaming pc build help
    Is this a good gaming pc?
    Could some one put together parts for a gaming pc for me?
New Build GPUs HD Radeon Systems Product
