Solved
Is 500 watts enough power?
Last response: in Components
September 30, 2012 4:59:14 AM
im considering buying -NZXT Crafted Series ATX Full Tower Steel Chassis - Phantom White
and i have a -evga geforce 550 ti 2gb
-ASUS M5A99X Evo - AM3+ - 990X - SATA 6Gbps and USB 3.0 - ATX DDR3 2133 Motherboards
-and i have the amd phenom ii x4 965
im wondering is 500 watts enough because i have that right now. i have the Cooler Master eXtreme Power Plus 500w Power Supply
More about : 500 watts power
a b ) Power supply
September 30, 2012 5:07:10 AM
500W would be vastly sufficient with a quality PSU.
Problem is that "quality PSU" and "CoolerMaster" rarely belong in the same sentence so your mileage may vary.
m
l
September 30, 2012 5:19:59 AM
^ what he said. but i have a coolmax psu its 600 watt i believe i have had it over 4 months now no problems everything runs perfecty fine i have the 1GB edition of the 550ti
m
l
a b ) Power supply
September 30, 2012 5:30:58 AM
+1 :lol:
m
l
September 30, 2012 5:39:16 AM
what would be a good psu that cost around 30-35 maybe 40 dollars because im low right now.
m
l
Best solution
a b ) Power supply
September 30, 2012 5:41:56 AM
For your rig, you wouldn't need much power, so something like this should suffice :)
a c 111 ) Power supply
September 30, 2012 5:42:39 AM
^+1
I use that in my Folding@Home rig which consists of a 4.5ghz 2500K and a 1ghz GTX 550ti! :D
m
l
September 30, 2012 5:44:12 AM
hmm i really don't want to buy another psu because i just bought the 500watts like 2 months ago.
m
l
a b ) Power supply
September 30, 2012 5:46:35 AM
Not sure there are any quality PSUs below $50 before rebates. Most good PSUs from the most frequently recommended PSU vendors are manufactured or designed by Seasonic.
You can try your CM first. If you run into boot-looping and random reboots, at least you know beforehand that your PSU will be the first thing to get pointed out.
m
l
September 30, 2012 5:56:46 AM
LOL ive ask this question before and some other person gave me the website. OK thx im gonna just keep my 500 watt psu
m
l
October 10, 2012 12:20:07 AM
Best answer selected by shadow2895.
m
l
