Will i have a size problem with this case?
here is the case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216&Tpk
here are my specs
CPU
i5 3570k
VID CARD
EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB
Motherboard
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
powersupply
CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91
heatsink
ZALMAN CNPS9500A-LED 92mm 2 Ball CPU Cooler
2 answers Last reply
More about will size problem case
  1. No, you won't run into any issues :)
  2. 1: evga ftw is overrated. msi power edition is way better in almost everything
    2: sabertooth is a gimmick. the v-pro is the same board but 20 bucks cheaper and without that plastic heattrapping shroud
    3:the xfx xxxx 750w is about the same as the hx750 but cheaper. 111 at amazon
    for this rig, id highly suggest the carbide 500R from corsair. no sizing problems with the 690 ii though
Power Supplies Components Product
