Processor problem
hello, last night i remove the processor and when i put that again my window is not booting and pictre is also not clear and the fan over processor is also rotating very fastplz help me
1 answer Last reply
More about processor problem
  1. hello,
    firstly, some specs of your pc would help so we can all see what hardware you are using.
    when you put the processor back in, did clean off then reapply the thermal paste between the processor and the heatsink? The fast fan would indicate you are burning up your cpu, so I would not try to boot up again until you have solved the issue.
    if you outline your exact steps in taking the processor out and putting it back in again, we can help.
CPUs Fan Processors
